It is currently Mon Jul 21, 2025 2:46 pm
PostPosted: Mon Feb 05, 2007 4:43 pm
Anyone out there use a cut off from the waste of back wood (oriented correctly of course) for their back reinforcement strip?
I typically use spruce or spanish cedar for these, but for some reason I was thinking of this.
Good idea or bad idea?
PostPosted: Mon Feb 05, 2007 7:00 pm
Jim,
Yes. It works fine.
PostPosted: Mon Feb 05, 2007 7:16 pm
Last Name: Abercrombie
Thats a pretty standard source for backstrips, I think. A lot of standard-size topsets seem to be quite oversize on length anyway.
I usually manage to find 'below standard' topwood somewhere in the junk pile. You can rip up (and bevel?) enough strips to last quite a while, and it makes things easier if you glue up a bit wider blank before you rip it up.
Or, like Larrivee, you can skip the backstrip....
PostPosted: Tue Feb 06, 2007 10:28 am
Jim, i also did this on no 3, i took some left over pieces from the WRC off cuts and it kind of look nice inside the ash box.
Here, have a peek through the soundhole
PostPosted: Tue Feb 06, 2007 10:29 am
OOOPS, misread, i thought you said off of the top, sorry Jim!
PostPosted: Tue Feb 06, 2007 11:50 am
Serge-
Obviously I didn't read the question carefully either...OOps all around.
Jim-
to answer your question, not what I imagined....
Some of the mahoganies or walnut would be ok to work cross-grain, but I have enough trouble with the more exotic back woods that I've never thought of making say a RW backstrip. The softer woods sand so easily that it simplifies things. And, if you are a gram counter, I suppose softwood strips are lighter as well.
But, it would look sharp. Let us know how it goes!
PostPosted: Tue Feb 06, 2007 12:45 pm
Yes, I think maybe I wasn't very clear in my original post, sorry about that. The question does concern hardwood back strips, I'm glad people picked up on it, i.e. rosewood strip on a rosewood back. I just don't remember seeing this and was wondering if I was missing something obvious on why it shouldn't be done.
I also like the look of spruce or spanish cedar for back strips though.
PostPosted: Tue Feb 06, 2007 12:57 pm
I just got an order from LMI and the spruce strips were too rough to use. So I cut off two strips off the back, glued one reinforcement strip to the back, and saved the other for another guitar.
I made it perfectly 3/4" wide on my router table. Then I ran it through twice again with a chamfer bit for a gorgeous very clean, no sanding finish. I'm throwing those other spruce ones in the trash. Looks like they were cut with a chainsaw there was so much tearout!
PostPosted: Tue Feb 06, 2007 6:50 pm
Jim,
They work fine - the cross grain patterns look funky. Here's an EIR one I did a year or two back:
PostPosted: Tue Feb 06, 2007 10:16 pm
What width do you guys make your re-enforcement strips?
I've learnt 6mm either side of the outermost joint (so if you've got a centre strip, they're a little wider) is what to shoot for.
Thoughts?
